More than one field in Conditional fields
8 years 11 months ago #4783 by Stefano
I searched on the site and the forum but without find a confirmation. It is possible to have more than one field shown by only one conditional field?
IE.
Field A (check box Yes|No)
If Field A is checked to NO Then:
Field B (text)
Field C (text)
Filed D (text)
Button
8 years 11 months ago #4784 by Stefano
Replied by Stefano on topic More than one field in Conditional fields
my bad...
the conditional field in the text field is at the very bottom of the page.. the first time I haven't saw it and the second time I have not save the new field before,
so no value in this field was showed.
In any case I suggest you to write that there is this possibility also in the documentation, where you talk about "Depth of conditions" field.
thank you
S.
