I cant display data in an article
8 years 5 months ago #5055 by trail
I cant display data in an article was created by trail
Hi ,
I am trying to display dat from a visform but i cant,
I have done everything.
Any help appreciated
Thank you
8 years 5 months ago #5057 by Administrator AV
Replied by Administrator AV on topic I cant display data in an article
i guess you want to use the content plugin data view for this.
Please make sure, that the content plugin data view is enabled.
Please make sure, that you have set up the "Frontend Data View options" in the form configuration properly
Allow frontend data view must be enabled for the form!
Please make sure, that the record sets, which you want to displayed are enabled (Data view in the administration).
Maybe you want to enable the form option "Auto Publish Data" so that new record sets are published by default.
For each FIELD which you want to display in Frontend, make sure that the you have set the Field Option Display Data in Frontend to a good value ("List" or "List and details"...)
Then follow the instructions in this documenation ( www.vi-solutions.de/en/documentations/vi...umentation-data-view ) in order to find the proper plugin string and add it to your article.
8 years 5 months ago #5058 by trail
Replied by trail on topic I cant display data in an article
Thank you Admin for your help.
I follow your instaruction and i made it. But at the top of the article i can see also the code
{vfdataview}{"formid":"2","fieldlist":"14,1,2,3,4"}{/vfdataview}
How can i hide this.
Thanks
8 years 5 months ago #5060 by Administrator AV
can you see this string and the data at the same time?
That would be very weird.
Usually the string is replaced with the data by the plugin.
When the plugin is not published, the string is not removed and you cannot see the data.
Can you send me a link to this view?
8 years 5 months ago #5061 by trail
Hi i havent publish the page yet.
Here you can see what is display at the article
{vfdataview}{"formid":"2","fieldlist":"14,1,2,15,4"}{/vfdataview}
ROUT LAST NAME FIRST NAME DATE OF BIRTH
23km +1400 / PAPADOPOULOS NICK 1970
8 years 5 months ago #5062 by Administrator AV
without taking a look at the side or better even the article configuration it is very difficult to help you because usually it everything is set up correctly this just works.
Is it possible, that you have added the (a plugin) string accidentally twice in your article.
In the plugin string that is visible there are 5 fields in the fieldlist, where in the list that is displayed it seems to me, that there are only 4 fields displayed.
Therefore I think, that maybe the list you see is not produced by the string which you still see.
One reason, why this second string is still visible could be, that there is some HTML mark up around it, that indicates that it is code and therefore it is not touched. (HTML pre or code element). You have to check this by switching the editor in the article configuration to the source code view.
