Cyrilic caratter problem export
8 years 6 months ago #5311 by antt7
Cyrilic caratter problem export was created by antt7
hi
I have problem with data export.
I use cyrilic caratters.
I have read topic vi-solutions.de/en/forum-index/19-joomla...2-french-accent#4850
but problem not solved
I set the "Windows-1250 Character Set" option in the form configuration tab "Advanced" to "no" .
I have read www.vi-solutions.de/en/documentations/vi...rms/314-save-results
but received in csv
Cannot decode.
UTF-8 does not work
windows-1251 the same
Coul you help me?
8 years 6 months ago #5318 by antt7
Replied by antt7 on topic Cyrilic caratter problem export
Problem solved.
There are two places to change "Windows-1250 Character Set" - in global settings and in form.
Thanks
