VISFORMS - Got radio and check box appears over form line
8 years 5 months ago #5363 by expertpc
Hello Team,
I have a problem when I configure your VISFORMS v3.10.4 module on Joomla 3.8.6.
When I check the result on my site, all radio/check boxes are OVER text.
there's the example of my problem
There is a solution or coding fix into one of the CSS files?
Denis
8 years 5 months ago #5366 by Administrator AV
Replied by Administrator AV on topic VISFORMS - Got radio and check box appears over form line
from a screenshot it is difficult to tell why the buttons/boxes are not displayed properly, because I cannot take a look at the HTML/CSS sources.
Basically Visforms provides different form layouts that render different html which is suitable for different template frameworks. If you have a Bootstrap 2 Template, please try a Bootstrap Layout as form layout. If you have a Boostrap 3 Template, we provide Bootstrap 3 Layouts with the Visforms Subscription. But if your template does not implement the Boostrap standards properly, then selecing a matching Bootstrap Layout in Visforms might not solve the problem completely.
So without a link to the form, it is not possible to tell you which customization might help.
