edit data in front end
8 years 4 months ago - 8 years 4 months ago #5443 by shinju
edit data in front end was created by shinju
Hello
i am trying to use the feature the edit data in font end . My problem is all the users in he group can see all the data submitted . I wan the logged in user to see only his submission. What is the settings that i should do for the same
Thanking You Sihnju
Last edit: 8 years 4 months ago by shinju.
8 years 4 months ago #5445 by Administrator AV
Replied by Administrator AV on topic edit data in front end
which records sets are visible in the frontend edit view, depends on the user permissions (ACL settings, made in the "Form Permissions" tab in the form confiugration or the "Permissions" tab in the Visforms global configuration).
If you want a logged in user of the user group "registered" only to see their own submission, you first have to make the following permissions settings for this user group.
Edit Data State "Inherited" (with "Calculated Settings" is "Not Allowed (Inherited) or "Denied"
Edit Data "Inherited" (with "Calculated Settings" is "Not Allowed (Inherited) or "Denied"
Edit own data "Enabled"
Then go the configuration of the menu item which you have created in order to display the data in frontend (Menu item of type Visforms >> form data with edit link). You will see a tab "Form Data Display Options" there. Set the option "Editable Record Sets Only" to "yes".
Nevertheless, if you use a menu item of type Visforms >> form data with edit link, Administrators will be able to see and edit all data which were submitted with the form. If you really want that only the user who has made the submission can see their on record sets, you have to use a menu item of type Visforms >> My Submissions as entry point for the edit view in front end. This menu item type really only displays the own data....
