Call to a member function get() on null after reload success page
8 years 3 months ago #5485 by bugreport1234
Hi Aicha,
I get an error if I reload the form success page after submit:
Fatal error: Call to a member function get() on null in /htdocs/components/com_visforms/views/message/view.html.php on line 46
I suppose it happens because there is no menu item associated with the form.
Fix: extra check at line 46+ of components/com_visforms/views/message/view.html.php
(Default values/types might not be appropiate, I haven't checked further)
$this->showReturnLink = false; $this->returnUrl = false; $this->linkText = ''; if( ! empty($this->menu_params) ) { $this->showReturnLink = $this->menu_params->get('textresult_previouspage_link'); $this->returnUrl = $this->menu_params->get('returnurl'); $this->linkText = $this->menu_params->get('linktext'); }
Hope it helps!
8 years 3 months ago #5486 by Administrator AV
Hi thanks,
yeah, I noticed the problem a while ago.
This bug was fixed with Visforms 3.11.0 which is currently released as a release candidate (and therefore not available through Joomla! Update manager yet). See: www.vi-solutions.de/de/support/dokumenta...orms/release-history
If you want to update to the Visforms release candidate, you can download the latest version (3.11.2) on the download menu.
Please note, that if you have a Visforms Subscription you have to update the Visforms Subscription to version 3.2.1 release candadate, too, then. (Also available on the download menu, after you have logged in with your Subscription user).
The following user(s) said Thank You: marcel-visform
