Options for Recipient mail
6 years 8 months ago - 6 years 8 months ago #6488 by van0358tz
Options for Recipient mail was created by van0358tz
Good Morning.
Using Visforms 3.13.8. Have also installed latest Visforms and subscription (Beta versions).
Joomla3.9.14
1) I have created a subscription form. In form I also have an email field (Email) where the user enters their email.
2) on the form setup, under the section mail options, I have set all settings. Also checked with the :
Documentation Visforms
Created: 28 May 2014
Last Updated: 19 January 2019
E-Mail Configuration
3) Under the sections "Options for result mail" and "Options for recipient mail" all settings have been set.
4) when the user submits form, I get all the results as expected and as declared via the "Options for result mail" settings.
Problem
Even tho I have all appropriate settings on the "Options for recipient mail" in the form (also checked settings in Visforms - Global Configuration), the user who has submitted form.
1) Does not get a copy of the subscription.
2) Does not get any email even If i also put information in the Email Receipt Text
I have checked this with my other emails that I have..
Any ideas of how to resolve this?
Regards
Vangelis
Last edit: 6 years 8 months ago by van0358tz.
6 years 8 months ago #6489 by Administrator AV
Replied by Administrator AV on topic Options for Recipient mail
Sending mails works perfectly fine with visForms. The Beta-Version is very well tested, too and there are no problems with sending the mails with the Beta-Version, too.
If you do not receive the receipt mail (= user mail) there are the following possible reasons.
1) You do not have enabled the "Send Mail" option for the receipt mail
2) you do not have a field of type "Email" in your form
3) When you submitted the form, the Email-field was empty or you have entered an Email-addresss, which does not belong to you
4) The mail was flagged as spam
6 years 8 months ago #6490 by van0358tz
Replied by van0358tz on topic Options for Recipient mail
Thank You,
All settings had been already set as indicated.
I have sent email with screen shots.
Looking forward to hear from you
Regards
Vangelis
