Submission Failure
6 years 6 months ago #6645 by Chicitadel
Submission Failure was created by Chicitadel
Hello Aicha,
I created a form to capture association's data using VisForms but the submission process is failing with the following error
Form submit failed Please select no more than 1 option(s) for field "Country of Nationality".
However, the Country of Nationality has no conditions related to number of selection. I have also tried to alter the field name except the required condition.
I also use Jotcache and JCH Optimizer to improve the site speed.
What is the possible cause? Please I need help on this.
6 years 6 months ago #6646 by Administrator AV
Replied by Administrator AV on topic Submission Failure
you probably have two or more options in your Country of Nationality field, that have the same option value.
This would be an invalid field configuration, which would result in exactly this error message.
6 years 5 months ago #6648 by Chicitadel
Replied by Chicitadel on topic Submission Failure
Hello Aicha,
That is exactly what happened,
I had a field listed twice which triggered the error, resolved now.
Thanks
