Form submit failed
6 years 4 months ago #6840 by naderfarid
Form submit failed was created by naderfarid
Hi. I need help.
I created a form but i get below error:
Form submit failed
We are sorry, but an error occured during form submit
I checked the setting and everything is okay
Could you please help me.
Website:
www.tekd.ca/index.php/free-trail
6 years 4 months ago #6841 by Administrator AV
Replied by Administrator AV on topic Form submit failed
please check the following, step by step.
Have you updated visForms and the Subscription to the latest version?
These are visForms 3.13.10 and subscription 3.4.11.
Have you made sure, that you do not have created overrides for visForms in your template,
Sometimes this just happens accidentally, if you click in "Templates -> Templates" (and then select your template) on the "Overrides" tab.
Could you please test, if not using the Recaptcha with the form, fixes the problem.
6 years 4 months ago - 6 years 4 months ago #6844 by naderfarid
Replied by naderfarid on topic Form submit failed
HI.
It doesn't work yet
- it is up to date on last version.
- I didn't have created overrides for visForms in the template.
- I'm using Recaptcha with the form and also I changed to Cisforms Captcha too but doesn't matter.
STILL NOT WORKING.
Could you please check below link. Thanks.
Last edit: 6 years 4 months ago by naderfarid.
6 years 4 months ago #6845 by Administrator AV
I can technicly tell, why this is not working.
Basicly the html-form element is closed to early and some important hidden inputs are therefor not part of the form and not submitted.
That causes the error.
I can further tell, that the html which is rendered by visForms in the first place, is not responsible for the invalide position of the closing html form element.
I have checked the visForms source code and all html elements are positioned properly there.
Further on, the uikit2 layout is used on many many websites and the form is rendered properly there.
So this must be some individual configuartion problem on your website.
This could be custom plugins (usually system or content plugins), Javascript that comes with your template.
Or maybe an invalide use of the recaptcha plugin.
In order to get this problem solved, you have to strip it down.
Disable the recaptcha Plugin and do not use a captcha with your form.
Disable all non Joomla! Core Plugins
6 years 4 months ago #6847 by Administrator AV
somehow you mananged to put a form into visForms.
There is a form "pirate_forms" inside the visForms form.
I think you use some sort of content plugin inside the custom text of your first visForms form field.
In HTML you must never have a form inside a form, that is invalide HTML an brakes everything.
I hope, with this additional information, you can fix the problem.
Just find out, where this pirate_forms comes from and remove it.
