CAPTCHA - reCAPTCHA
4 years 11 months ago #7653 by rusasadmins
CAPTCHA - reCAPTCHA was created by rusasadmins
=13pxThere is a ReCaptcha error coming from a Visform on our site:   rcha.rutgers.edu/teacher-workshop-registration
The Joomla CAPTCHA - reCAPTCHA plugin is set to Version 2.0.  I've checked to make sure the correct ReCaptcha keys were entered.
The errors below show in the browser's Console.  I am wondering if anyone can determine from this if it is an issue with the ReCaptcha, Visforms or some kind of conflict.  The URL for the CSS file does not work.
GEThttps://www.gstatic.com/recaptcha/releases//styles__ltr.css
[HTTP/3 404 Not Found 34ms]
GEThttps://www.gstatic.com/recaptcha/releases//recaptcha__en.js
[HTTP/3 404 Not Found 162ms]
The resource from “https://www.gstatic.com/recaptcha/releases//styles__ltr.css” was blocked due to MIME type (“text/html”) mismatch (X-Content-Type-Options: nosniff).
The resource from “https://www.gstatic.com/recaptcha/releases//recaptcha__en.js” was blocked due to MIME type (“text/html”) mismatch (X-Content-Type-Options: nosniff).
Uncaught ReferenceError: recaptcha is not defined
    <anonymous> www.google.com/recaptcha/api2/anchor ?[object Map Iterator]=[object Map Iterator]:179
4 years 11 months ago #7654 by rusasadmins
Replied by rusasadmins on topic CAPTCHA - reCAPTCHA
The Visforms captcha does work, so it seems this may be a Google ReCaptcha issue. I will leave the Visforms captcha enabled.
Thanks!
