Hiding some fields in Form Data view
4 years 7 months ago #7890 by hktanty
Hiding some fields in Form Data view was created by hktanty
Hello,
Form Data is to display data sets of a single form. But I have 10 fields in that form. I just want to display 4 fields to end users. But I am not able to do this and it displays all 10 fields and clutters the screens. Also end users also gets confused with many information which are not relevant to them.
If any one know the solution to this, then kindly reply. Thanks in advance for any sort of help.
Hemanta Tanty
4 years 7 months ago #7891 by Administrator AV
Replied by Administrator AV on topic Hiding some fields in Form Data view
Hello hktanty,
a form field that must not appear in the Visforms data view to end users has just to be configured accordingly:
Field configuration --> tab 'Advanced' --> parameter 'Display Data In Frontend' = 'Don't show'.
Best regards, Ingmar
4 years 7 months ago #7892 by hktanty
Replied by hktanty on topic Hiding some fields in Form Data view
Hello Admin,
Thanks for the quick reply to my post. I am blessed to be part of this group. However my scenario is like this:
I have a form (say form1) with 10 fields.
1) For data entry, I have created a menu item (say form1_entry) which is Visforms menu type Form (display a single form). Here few registered users will do valid data entry for all those 10 fields on Frontend.
2 For data display, I have created a menu item (say form1_report) which is Visform menu type Form Data (display data of single form). Here I want to display 4 fields on Frontend to larger public.
Now if I set Display Data in Frontend = Don't Show for 6 fields, then these fields will not show in Frontend. Then how the data entry (1) will happen?
This is my problem. Please advise if there is any solution to this. As Form Data is to display Single Form Data and after selecting the form, there should be some facility for us in selecting relevant fields for displaying.
Thanks & Regards,
Hemanta Tanty
4 years 7 months ago #7893 by Administrator IV
Replied by Administrator IV on topic Hiding some fields in Form Data view
Dear Hemanta,
I am very glad that you are part of the group!
There is no problem as the menus you created work exactly as you like them to work.
The field parameter 'Display Data In Frontend' controls only the visibility of the user data that was already sent by form submits, which is the view of your menu item 'form1_report'.
The fields on the form itself do not hold any 'data' in that sense yet.
The data gets data in the sense of 'Display Data In Frontend' if it was sent by a form submit to the server and got saved.
Unless a field on the form is of type hidden or suppressed by any conditional-field logic, the field on the form is always visible to the user, which is the view of your menu item 'form1_entry'.
Here is an example form in accordion layout having 9 fields:
Form section 1 opened (3 fields):
[url] vi-solutions.de/forum-uploads/pagebreak-...cordion-section1.png [/url]
Form section 2 opened (4 fields):
[url] vi-solutions.de/forum-uploads/pagebreak-...cordion-section2.png [/url]
Form section 3 opened (2 fields):
[url] vi-solutions.de/forum-uploads/pagebreak-...cordion-section3.png [/url]
The data view only shows 3 fields - having set 'Display Data In Frontend' = 'List and details':
(all other fields having set the default value 'Display Data In Frontend' = 'Don't show')
[url] vi-solutions.de/forum-uploads/pagebreak-...data-in-frontend.png [/url]
