Pre-Populate field with url value
4 years 1 week ago #8371 by jhudson_jvh
Pre-Populate field with url value was created by jhudson_jvh
Can you provide an example of the URL formating to prepopulate a filed with the variable inside URL? I am not able to get this to work. The variable shows in the URL, but it doesn't populate the form even after setting the Allow URL Parameter to yes. Not sure what I am missing.  Can you assist? Ideally, I want to use this in a dynamic dropdown SQL query for another field.
4 years 4 days ago - 4 years 4 days ago #8376 by Administrator IV
Replied by Administrator IV on topic Pre-Populate field with url value
Hello jhudson_jvh,
the documentation describes the use of URL parameters to set a default value quite extensively:
docs.joomla-4.visforms.vi-solutions.de/e...ue-as-url-parameter/
Let me know if you don't get along with this description either.
In this case it would be nice if you could describe your use case a little more precisely.
Best regards, Ingmar
Last edit: 4 years 4 days ago by Administrator IV.
4 years 4 days ago #8377 by Administrator IV
Hello jhudson_jvh,
The URL parameter for a form field can only contain fixed values.
For the plugin 'Content Plugin - Visforms form', placeholders for various other information can also be set for the plugin string:
docs.joomla-4.visforms.vi-solutions.de/e...#page-url-as-default -value
The placeholders that are possible for the plugin string above cannot be set in the URL parameter for a form field.
For a form field, these values can only be selected in the field configuration:
docs.joomla-4.visforms.vi-solutions.de/e...dividual-field-types
4 years 23 hours ago #8387 by jhudson_jvh
Replied by jhudson_jvh on topic Pre-Populate field with url value
Apologies for not responding earlier. I am able to place variables in the URL in the form without any issues. The challenge I am having is when I try to use this variable in a new form and set it as the default value as input for a subsequent SQL.For example URL = index.php/quotation-results?formidno=6323e699ce6509.90819428
Where formidno is what I would like to use in a custom default value from SQL in this new form, is this possible with this module?
3 years 11 months ago - 3 years 11 months ago #8398 by Administrator IV
Hello jhudson_jvh,
I am truly sorry for my late reply!
I built an example form that behaves like I think you like to have it.
Example:
Form name = 'calculation-form'
Form ID = 11
The default value of field 'number2' is set via the URL parameter.
The default value of field 'number3' is set via an SQL statement that uses the URL parameter for field 'number2' (in the most simple way).
The local test calling URL is: localhost/developj4/index.php/calculation-form?form11number2=2345
The form called by this URL shows like this:
vi-solutions.de/forum-uploads/pre-popula...h-url-value_form.png
The field configuration part of field 'number3' is:
vi-solutions.de/forum-uploads/pre-popula...ld-configuration.png
Explanation:
You can use values from the Joomla user object, the current Joomla user, or values from the current Joomla input object.
More on this in: docs.joomla-4.visforms.vi-solutions.de/e...field-default-value/
The URL parameter for field 'number2' is part of the Joomla input object.
The parameter has the name 'form11number2' in the Joomla input object.
More on this in: docs.joomla-4.visforms.vi-solutions.de/e...#the-parameter-value
I hope this answers your question!
Last edit: 3 years 11 months ago by Administrator IV.
3 years 11 months ago #8414 by jhudson_jvh
Thanks for taking the time to explain and provide details. This looks like it can work. I will try it and if I have any challenges I will reach out. Thanks again.
