visforms in the article
3 years 4 months ago #9253 by sqs
visforms in the article was created by sqs
Hello, I do not see the wisforms module embedded in the articles or in the custom content module in Joomla4 on my website. Could you give me an advice please? Thank you Milan
3 years 4 months ago #9261 by Administrator AV
Replied by Administrator AV on topic visforms in the article
Hello Milan,
embedding a module in an article or in a custom content module is a default Joomla feature.
It works with the Visforms module just like with any other Joomla module.
There is nothing special with the Visforms module.
So this is probably a misconfiguration.
Please provide exact information, what you set up and how, if you need further help.
3 years 4 months ago #9262 by sqs
Replied by sqs on topic visforms in the article
Thanks for the reply, I can see the other modules.
Is there a limitation in Visforms? Previously, it was necessary to activate the plugin.
Thank you Milan
3 years 4 months ago #9268 by Administrator AV
Hi Milan,
there is no limitation in Visforms.
Sorry, your information is a bit sketchy.
Can you describe it in a bit more detail and/or attach screenshots?
In order to be able to help you, we need exact information how you are setting this up.
