Visforms requires "Behaviour - Backward Compatibility" plugin
2 years 9 months ago #9898 by rusasadmins
I discovered that when trying to use Visforms with Joomla! 5, the "Behaviour - Backward Compatibility" plugin is required - otherwise, the front end of the website returns the error:
0: Class "JObject" not found
Are there plans to make Visforms work in Joomla! 5 without requiring the "Behaviour - Backward Compatibility" plugin?
2 years 9 months ago #9901 by Administrator IV
Hello rusasadmins,
Joomla introduced this 'Backwards Compatibility Plugin' to minimize problems with Joomla 5.
We also still use this option for the current Visforms version 4.4.0 under Joomla 5.
The next Visforms version 5.0.0 is in progress and will no longer require this plugin.
Unfortunately, there is no exact release date yet.
We already created a development issue for this issue:
Issue [VF-937] J5: remove the dependency on the Joomla plugin 'Behavior - Backward Compatibility'
Thank you for your question!
Kind regards, Ingmar
