vfsubscription_j4.0.0_4.4.0 lässt sich nicht installieren
2 years 8 months ago - 2 years 8 months ago #10032 by Yakidi
Hallo
Die Erweiterung vfsubscription_j4.0.0_4.4.0 lässt sich nicht  installieren.
Es ist ein Fehler aufgetreten.
0 Class "ZipArchive" not found
Call Stack#FunctionLocation
1 ()JROOT\tmp\install_65b55669dfa2b\script.php:670
2 pkg_vfsubscriptionInstallerScript->installPdfFonts()JROOT\tmp\install_65b55669dfa2b\script.php:191
3 pkg_vfsubscriptionInstallerScript->preflight()JROOT\libraries\src\Installer\LegacyInstallerScript.php:158
4 Joomla\CMS\Installer\LegacyInstallerScript_call()JROOT\libraries\src\Installer\LegacyInstallerScript.php:187
5 Joomla\CMS\Installer\LegacyInstallerScript>callOnScript()JROOT\libraries\src\Installer\LegacyInstallerScript.php:98
6 Joomla\CMS\Installer\LegacyInstallerScript>preflight()JROOT\libraries\src\Installer\Adapter\PackageAdapter.php:590
7 Joomla\CMS\Installer\Adapter\PackageAdapter>triggerManifestScript()JROOT\libraries\src\Installer\InstallerAdapter.php:714
8 Joomla\CMS\Installer\InstallerAdapter->install()JROOT\libraries\src\Installer\Installer.php:652
9 Joomla\CMS\Installer\Installer>install()JROOT\administrator\components\com_installer\src\Model\InstallModel.php:214
10 Joomla\Component\Installer\Administrator\Model\InstallModel>install()JROOT\administrator\components\com_installer\src\Controller\
InstallController.php:52
11 Joomla\Component\Installer\Administrator\Controller\InstallController>install()JROOT\libraries\src\MVC\Controller\BaseController.php:730
12 Joomla\CMS\MVC\Controller\BaseController>execute()JROOT\libraries\src\Dispatcher\ComponentDispatcher.php:143
13 Joomla\CMS\Dispatcher\ComponentDispatcher>dispatch()JROOT\libraries\src\Component\ComponentHelper.php:361
14 Joomla\CMS\Component\ComponentHelper::renderComponent()JROOT\libraries\src\Application\AdministratorApplication.php:150
15 Joomla\CMS\Application\AdministratorApplication>dispatch()JROOT\libraries\src\Application\AdministratorApplication.php:195
16 Joomla\CMS\Application\AdministratorApplication>doExecute()JROOT\libraries\src\Application\CMSApplication.php:306
17 Joomla\CMS\Application\CMSApplication>execute()JROOT\administrator\includes\app.php:5818require_once()JROOT\administrator\index.php:32
visforms_update.php:
INFO    ************ package installation: subscription ( 2024-01-27 19:15:54 ) ************
INFO    ****** package running in: [ROOT]|tmp|install_65b55669dfa2b
INFO    ****** starting script file: subscription package - administrator/manifests/packages/vfsubscription/script.php ******
INFO    start preflight
INFO    write access to filesystem possible
INFO    *** start install of extension pkg_visforms_subscription 4.4.0: 2024-01-27 19:15:54 ***
INFO    PDF fonts not installed
INFO    PHP directive 'allow_url_fopen' set to: 1
INFO    PDF fonts can be installed due to PHP settings
INFO    *** trying to install pdf fonts ***
Was kann ich tun?
Last edit: 2 years 8 months ago by Yakidi.
2 years 8 months ago #10033 by Administrator IV
Replied by Administrator IV on topic vfsubscription_j4.0.0_4.4.0 lässt sich nicht installieren
Hello Yakidi,
you are missing a very common PHP module on your server.
In the following topic the same problem occurred 11 months ago.
"Internal Server Error" when installing subscription package:
vi-solutions.de/de/forum/19-joomla-exten...package?start=6#8984
This post also mentions a workaround if, for whatever reason, you are not allowed or unable to install the PHP Zip extension:
vi-solutions.de/de/forum/19-joomla-exten...ackage?start=12#8989
Quote:
For the ZipArchive class to be present, PHP needs to have the zip extension installed.
So you need to install the PHP zip extension.
Kind regards, Ingmar
2 years 8 months ago #10041 by Yakidi
Thank you very much! It worked perfectly.
The "php_zip.dll" was already there. I only had to add the entry "extension=php_zip.dll" in php.ini.
