Age Check
2 years 6 months ago #10185 by trail
Age Check was created by trail
HiIs it possible in the form when someone who is a minor registers to display an extra field to write the details of the parent? This is a running event and I would like to see if this option exists. Thanks
2 years 6 months ago #10188 by Administrator IV
Replied by Administrator IV on topic Age Check
Hello trail,
Unfortunately, you leave completely open how the form finds out that I am a minor.
Case 1:
So I'm just assuming that you have a checkbox field to indicate 'minor' in your form.
In this case, the simple solution with a conditional field works for you.
Conditional fields are described in the documentation.
Case 2:
You have an age field in your form.
Unfortunately, this option does not exist in Visforms as a simple configuration.
You can achieve the behavior with some custom JavaScript and the Visforms 'Frontend Webassets'.
In this case, the small JavaScript code would have to do the following:
- The value of the age changes
- greater than or equal to 18
- then show another field.
The Visforms 'Frontend Webassets' are described with practical examples in the documentation.
Frontend Web Assets:
docs.joomla-4.visforms.vi-solutions.de/e...-frontend-webassets/
All settings are made in the form:
docs.joomla-4.visforms.vi-solutions.de/e...are-made-in-the-form
Examples of solving requirements with the frontend web assets:
docs.joomla-5.visforms.vi-solutions.de/e...-webassets/examples/
Further examples:
docs.joomla-5.visforms.vi-solutions.de/e...ets/examples-more-1/
Kind regards, Ingmar
