Visform does not send the form and data to users and admin.
1 year 5 months ago #11432 by naderfarid
After the user completes the form, the system should send the PDF and CSV form via email to the user and the admin, but this does not happen and apparently all the settings are correct. The email sending system also works perfectly fine.
Also, the download link that is loaded on the final page (after submitting the file) does not work and gives an error when clicking on the link.
how should I send you the user and password of the admin panel? here?
1 year 5 months ago #11435 by Administrator IV
Hello naderfarid,
Thanks for the two screenshots.
Do not send us your login information here in the forum.
If necessary, please email us at: forum (--at--) vi-solutions.de.
We usually need an Akeeba backup of the site to be able to debug the situation locally.
Quote:
As of version 5.4.0, there is explicit logging for email sending.
Enable logging for email sending:
vi-solutions.de/forum-uploads/inspector-...le-email-logging.jpg
Logging for email sending in the Inspector:
vi-solutions.de/forum-uploads/inspector-...bmit-log-entries.jpg
Q1 - Can you please do the following?
- Enable logging for email sending for user email and administrator email:
Form Configuration >> 'Email Options' tab >> 'Admin Email' and 'User Email' sub-tabs >> 'Logging' group >> 'Log email sending' parameter = 'Yes'.
- Submit the form.
- Check the log file in the Inspector on the 'Submit' tab for email sending.
- Show us a meaningful screenshot of the log file or add the log file to the topic (copy, rename to *.txt, upload).
- Show us a meaningful screenshot of both email configurations.
Best regards, Ingmar
1 year 5 months ago #11436 by Administrator IV
Hello naderfarid,
Q2 - Does sending emails with the same form work if you disable PDF and CSS attachments?
