Visforms 6.2.2 – Uploaded Images Resized to 2048 Pixels Despite 4000-Pixel Setti
3 weeks 4 days ago #12632 by UKtrev
Hello Ingmar,Thank you for your earlier help. I now have ten conditional upload fields working in my Project Information Questionnaire.I have encountered another issue with image resizing.I am using Joomla 6.1.4 and Visforms 6.2.2.All ten upload fields have:
  • Drag & Drop Upload: Yes
  • Resize large images: Yes
  • Maximum image width: 4000
  • Maximum image height: 4000
However, when I upload a photograph originally measuring 3024 × 4032 pixels (approximately 8 MB), the stored image is reduced to 1536 × 2048 pixels, approximately 800 KB.Before enabling image resizing, Visforms stored the original photograph at its full resolution.Is there an additional image-size or compression setting that overrides the dimensions specified in the upload fields? Does the drag-and-drop uploader have a separate maximum resolution?I need to retain reasonably high resolution because customers upload photographs of sign locations, and I often need to zoom into distant details.Thank you for your assistance.
3 weeks 2 days ago #12645 by Administrator IV
Hello Trevor,
Thank you for your clear description of the settings, as well as the expected versus actual behavior of the upload field.
Re: I need to retain reasonably high resolution
Just a quick update:
- I am already looking into your issue.
- It is taking a bit longer than expected, unfortunately.
Kind regards, Ingmar
3 weeks 44 minutes ago - 3 weeks 37 minutes ago #12653 by Administrator IV
Hello Trevor,
Your objection to an acceptable image resolution is understandable.
Current status:
According to the Visforms configuration inline help, the image size is limited when 'Resize large images' is selected.
Maximum image width:  The maximum allowed value is 2048 px.
Maximum image height: The maximum allowed value is 2048 px.
The limitation is intentional in that it respects the existing size limitations of the underlying Canvas HTML5 element.
The underlying Canvas HTML5 element is not only limited in size in all browsers depending on the hardware.
The size limit varies greatly between hardware, platforms, browsers, operating systems and versions used.
The underlying Canvas HTML5 element crashes, throws a JavaScript error, and does not display an image at all if its size limit is exceeded by selecting an image.
The limit in Visforms to 2048 px is very safe and admittedly conservative in order to work without errors everywhere.
Our customization:
There are actually 2 browsers (IE Windows Phone) and Safari that have a maximum of 4096 px.
All others are significantly higher.
We have now decided to increase the limit in Visforms to 4096 px.
This means your requirement is also possible.
We will also adjust the labels for the options.
Maximum image width (max. 4096px)
Maximum image height (max. 4096px)
I have created the following development issue in the feature wish list:
Issue [VF-1616] Forum: Crop and resize images on upload: Extend the current size limit of 2048 px
There will also be a file-based fix for this change in the very short term.
Thank you again for your contribution.
Last edit: 3 weeks 37 minutes ago by Administrator IV.
2 weeks 6 days ago - 2 weeks 6 days ago #12659 by Administrator IV
Hello Trevor,
There is a hotfix available to increase the limit to 4096 px for:
Joomla 6 and the current version of Visforms 6.2.2.
Please back up the existing file beforehand, just in case any unexpected issues arise.
Download the following file:
- vi-solutions.de/forum-bugfixes/visforms-upload.js_6.2.2.txt
Rename the downloaded file to:
- visforms-upload.js_6.2.2.txt
Use this renamed file to overwrite the following file on your server:
- media/com_visforms/js/visforms-upload.js
Note:
This hotfix increases the limit to 4096 px.
It does not yet include the display of this limit within the options label.
Last edit: 2 weeks 6 days ago by Administrator IV.
