invalid address after sending form
10 years 5 months ago #2800 by IreneLennings
invalid address after sending form was created by IreneLennings
Dear Aicha,
It's been a while...but here's a problem.
I upgraded to:
Joomla 3.5.1
Visforms 3.6.11
After sending the form the following page appears:
joopvangoozen.nl/index.php/contact?task=visforms.send&id=1
Invalid address
This also happens when I fill in a redirect URL
The messages are sent correctly.
Do you know what the cause could be?
Let me know if you need access to the backend.
Many Regards
Lenneke
10 years 5 months ago #2803 by Administrator AV
Replied by Administrator AV on topic invalid address after sending form
Hi Irene,
please make sure that you have entered a valid email address in the form option "Mail From Address" for the result and the receipt Mail.
Obviously it was not necessary to fill this option with previous Jooomla! Versions but on Joomla! 3.5.1 this is requiered.
Please let me know, if this fixes your problem.
The following user(s) said Thank You: IreneLennings
10 years 5 months ago #2826 by IreneLennings
Replied by IreneLennings on topic invalid address after sending form
Yes it does fix the problem!
Very grateful for your help!
Wouldn't it be better though to make it a required field :) ?
Regards
Irene
10 years 5 months ago #2827 by Administrator AV
Hi Irene,
I considered that, for the last days, too.
With older Joomla! Versions it was not necessary to fill this option. And if you have set the "send mail" to "no" and the field is required, the validation will always force you to enter an email even if you do not want to send mail.
But I will try to figure a solution, because I think that you are correct.
So thanks for your suggestion.
