Hide Label for Textarea
9 years 7 months ago - 9 years 7 months ago #3326 by Gabor
Hide Label for Textarea was created by Gabor
Dear Aicha,
I use Visforms Version 3.7.7 on Joomla 3.6 and I would like to hide a Label but the Label Options dropdown not showing on Textarea field. It is visible on Text and E-mail fields.
Can you fix this please in future release?
Thank you,
Gabor
Last edit: 9 years 7 months ago by Gabor.
9 years 7 months ago #3327 by Administrator AV
Replied by Administrator AV on topic Hide Label for Textarea
Hi Gabor,
I included this feature in Visforms 3.8.3.
Visforms 3.8 is the current beta Version. But I think you can savely use it.
It is a beta mostly, because I added lot's of new features and there will probably be updates more often than for the stable version. But from the perspective of functionality it runs quite stable.
You have to go to the downloads menu and find the download for Visforms 3.8.3 beta there and install is manually.
Hiding the label on textareas is only possible, if the option "HTML Editor" set to no.
The following user(s) said Thank You: Gabor
9 years 5 months ago - 9 years 5 months ago #3572 by fede491
Replied by fede491 on topic Hide Label for Textarea
Hi Aicha,
Now i use Visforms Version 3.8.9. The Label Options dropdown not showing on Select field also.
Thank you,
Federico
Last edit: 9 years 5 months ago by fede491.
9 years 5 months ago #3573 by Administrator AV
this is the intended behavior.
The label informs the user, what they should do with a field. If a field type has the option "hide label" and you set this option to yes, then the field label is displayed as a placeholder in the fields input element. So the user still knows what they are supposed to do. For Checkboxes, radios and selects. there is no way to display the filed label as a placeholder. That is, why there is no option "hide label" for these field types.
9 years 5 months ago #3574 by fede491
The first item of a select field can explain to users what they are to do, or if the form is included in a table like this:
Day Month Year
1 Select Select Select
2 Select Select Select
3 Select Select Select
labels on select field are not necessary for me.
Thank you, Federico
9 years 5 months ago #3575 by Administrator AV
ok, I understand what you mean.
I'll consider it.
Maybe you can hide the label with css?
