multi check box in ver.2.1.2
9 years 6 months ago #3502 by stavroch
multi check box in ver.2.1.2 was created by stavroch
I have Joomla 2.5 and I install the Visforms Version 2.1.2.
How can I add check boxes with multi choices?
I use the check box group in your latest versions. What about the old versions?
9 years 6 months ago #3503 by Administrator AV
Replied by Administrator AV on topic multi check box in ver.2.1.2
the field type checkbox group was developed in a later Version of Visforms.
As Joomla! 2.5 is no longer supported by Joomla! itself, there is no further development for Visforms Version which run on Joomla! 2.5, too and no support either.
It's just a courtesy that I still provide the download of the latest Visforms version for Joomla! 2.5 (because you you have to update Visforms on Joomla! 2.5 to this version, before updating to Joomla! 3).
It is strongly recommended to update to a save current Joomla! Version.
9 years 6 months ago #3504 by stavroch
Replied by stavroch on topic multi check box in ver.2.1.2
Can you please provide me the url of the latest component?
9 years 6 months ago #3505 by Administrator AV
Please check out the downloads menu. You will find the latest version for Joomla! 2.5 there.
9 years 6 months ago #3506 by stavroch
I have install the version 2.1.2. Is that the latest version?
Can you please let me know what is the latest version number?
9 years 6 months ago #3511 by Administrator AV
yes this is the latest Version for Joomla! 2.5
