Visform doesn't works as well
9 years 2 months ago #3874 by gigiograndi
Visform doesn't works as well was created by gigiograndi
Hy
We're customizing new form and everything seems to ne fine, but now we aren't anke ti start a request anymore: fields are unselectable. Why?
Please, take a look
www.collaefresu.com/tuvonella2/
Regards
9 years 2 months ago #3876 by Administrator AV
Replied by Administrator AV on topic Visform doesn't works as well
you use on your website custom javascript which modifies the html code of form elements which is created by Visforms. It modifies the values of class attributes and modifies HTML Tags in the form HTML structure.
(Especially it modifies the select field type with javascript to a so called choosen select).
Visforms absolutely relies on the HTML code structure which is created by the Visforms code itself. So you cannot use this kind of custom javascript (which is maybe added by your template) on pages where you have Visforms forms.
9 years 2 months ago #3878 by gigiograndi
Replied by gigiograndi on topic Visform doesn't works as well
Hy
we tried other templates, only for that page but doesn't works. Please, this is very important, help us!
9 years 2 months ago #3879 by gigiograndi
Hy,
forgive me, it was my terrible fault: I've selected "unique value only" in the advanced features of first field.
Everything's fine now, no javascript problem.
Bye!
