Question about pro
9 years 1 month ago #3902 by EnSoi
Question about pro was created by EnSoi
Not sure this is the right place but I have questions about the pro version.
My first question is does the pro version have a time limit or is it only a time limit for the support (do I need to pay every "timeframe" in order to keep pro going)?
Second question, if I want the client to add a credit card, will I be able to see it and anyone else won't? Is this included in pro?
Thanks!
9 years 1 month ago #3903 by Administrator AV
Replied by Administrator AV on topic Question about pro
the "timelimit" of the subscription does only concern the ability to get updates. The files and features do not stop to work after your subscription is expired. This would only be a problem if you need the updates.
About your second question. I think you are asking, if you can set a access level for data view on field level. This is not part of the subscription.
9 years 1 month ago #3906 by EnSoi
Replied by EnSoi on topic Question about pro
Hi, My second question was in there a filed where a user can safely add a credit card? and that i can read it afterwards.
Another question is, is it possible for a user to only see there own answers and not the answers of everyone?
Thanks!!
9 years 1 month ago #3907 by Administrator AV
I don't know whether the way how you can "protect" data with Visforms is sufficient with regards to legal requirements for credit card information.
Basically already in the free Version of Visforms you can decide for each field individually whether or not it's data are displayed in the frontend data view. But if thay are displayed, then everybody who has access to the data view can see these data. In the administration of your website you can see all submitted data.
At the moment Visforms does not have an option "display own submissions only" for the frontend data views, but I'm sure that this feature will be one of the next which I will add to the subscription. At the moment there are only "workarounds" using the content plugin data view, restricting access to logged in users and using a user specific value (i.e. user mail) for data selection. But this workaround does not make it impossible for other logged in users to view data of other users if they really know how Visforms and really want to see the data.
