Form Data Display not working
8 years 11 months ago #4213 by mikepritchard
Replied by mikepritchard on topic Form Data Display not working
just sent, thanks much.
8 years 11 months ago #4214 by Administrator AV
Replied by Administrator AV on topic Form Data Display not working
you forgot to enable the display data in frontend on field level. (Field configuration, tab "advanced").
8 years 11 months ago #4215 by mikepritchard
I must be blind because I can't find that anywhere. Is that on the form advanced tab?
8 years 11 months ago #4216 by Administrator AV
FIELD configuration
You have to set for each field individually, that the data submitted for this field, are visible in the front end.
8 years 11 months ago #4217 by mikepritchard
Got it. I have never set that before, the default must have changed at some point to:
Display Data In Frontend: (Don't Show)
I am including my notes here in case anyone else has this problem:
not only do you create the menu item you also have to be sure to set:
Your Form/ Result to save results,
Your Form/ Dataview in Frontend set to Allow...
Your Form/ each field must be set individually. Click on Advanced tab in the individual field then under Usage change "Display Data in Frontend to "list and details"
Thanks,
Mike
8 years 11 months ago #4218 by Administrator AV
the default was changed years ago, because with the original default settings there could be an unintentional discloser of user data.
Thanks for your brief and helpful notes. You missed one setting
Your Form/ Data view in Frontend set Autopublish Data to Yes
