Mobile display error with 2 column layout
8 years 10 months ago #4256 by designmultimedia
Mobile display error with 2 column layout was created by designmultimedia
Hi and compliments for the component. I have a problem, I set my form with a multi-column 2 layout all properly visible in the desktop version while the mobile text area becomes very small and you do not see what you are writing. I can't attach screenshots.
www.professionequinto.it/preventivi
Thank you
8 years 10 months ago #4257 by Administrator AV
Replied by Administrator AV on topic Mobile display error with 2 column layout
this is the result of the css that comes with your template.
Visforms itself tries to fit into the look and feel of your template. Therefore the css that comes with Visforms, uses week selectors, so that usually the css of your template is used, in order to give layout to the form.
You will have to add some custom css in order to fix this.
Maybe the article www.vi-solutions.de/en/documentations/vi...form-layout-with-css is of some help.
(I think basically the problem is that your bootstrap.css sets the line height to 20px, the height of the input element to 20 px and then set paddings on the input element. Maybe enhancing the height of the input elements to 30px will fix it.)
The following user(s) said Thank You: designmultimedia
