Captcha Custom Error Text disables submit and reset buttons
8 years 10 months ago - 8 years 10 months ago #4361 by Jesus
Hi all.
I've found two issues on visforms 3.8.24 (over Joomla 3.7.2):
1) If I enter a text in the "Captcha Custom Error Text" on the "Spam Protection" folder of a form, then the submit and reset buttons become disabled like if there was some jScript error;
2) All bootstrap layouts now have a little problem: the Recaptcha Plugin box appears on top of the line that is supposed to separate it from the button-type fields on the form, This issue didn't happen in the 2.7.X versions of Visforms. The correct behaviour is only obtained if the form uses the default layout (wich I cannot use because I need a two-columns form). Althought this is very easy to replicate, I can provide print-screens if necessary.
Thank you for all the attention.
Reagards
M. R. Jesus
Last edit: 8 years 10 months ago by Jesus.
8 years 9 months ago #4369 by Administrator AV
do you have the same problem, when you enter custom error texts with Visforms fields?
Could you please check, if the layout problem with the recaptcha Plugin is still there with Visforms 3.8.25.
I made some changes to the view files, and maybe this problem was solved be these changes. If not, I will take a look at it next monday.
8 years 9 months ago #4417 by Jesus
Hi.
I'm sorry for such a late feedback.
After upgrading for the 3.9.0 version, I realize that it all remains as it was before: the Recaptcha Plugin box appears on top of the line that is supposed to separate it from the button-type fields on the form.
Custom error texts do not have any problem if related to regular form fields; the issue is strictly related to the text in the "Captcha Custom Error Text".
I can send print-screens or even the website's URL, should you tell me how.
Thank you.
M. R. Jesus
8 years 9 months ago #4418 by Administrator AV
please send me screenshot to contact@vi-solutions.de but further on it would be helpful to have a link to the form, in order to view the html source code directly.
I have tried to reproduce the problems in the meantime, but on my test system, using the Joomla! default template Protostar, I cannot reproduce the problem.
