Other Captcha plugins
8 years 9 months ago #4435 by ferino
Other Captcha plugins was created by ferino
Would it be difficult to incorporate other captcha plugins into the Visforms component?
Ideally all that are installed in Joomla. :)
If it was very complicated, would this plugin be at least?
https://extensions.joomla.org/extensions/extension/access-a-security/site-security/aimy-captcha-less-form-guard/
Thanks.
8 years 9 months ago - 8 years 9 months ago #4436 by Administrator AV
Replied by Administrator AV on topic Other Captcha plugins
the main spam protection strategy of Visforms which also makes it stand out against other form components, is the build in plugin spambotcheck and not the use of captchas. Most users don't really like to fill in captchas. Most captchas do not really prevent spam for a long time (spammers adapt to the captcha and get around it).
Maybe the following documentation article would be informative for you and you could try using the build in spambotcheck plugin:
www.vi-solutions.de/en/documentations/vi...t-forms-against-spam
Therefore we do not want to put lots of efforts in including more and more captcha plugins into Visforms.
And yes it does take some (a considerable amount of) time and work to add other captcha plugins.
I'm sorry.
Last edit: 8 years 9 months ago by Administrator AV.
8 years 9 months ago #4437 by ferino
Replied by ferino on topic Other Captcha plugins
OK.
So, in your opinion, just use your spambotcheck plugin?
8 years 9 months ago - 8 years 9 months ago #4438 by Administrator AV
Yes. At least give it a try.
8 years 9 months ago #4439 by ferino
OK. thanks.
