Multilanguage not working
13 years 3 months ago #128 by xtime123
Multilanguage not working was created by xtime123
On the Joomla extensions directory it says Visforms supports Joomla 2.5 languages natively, but it doesn't work for me.
I have the form in English, which works just fine.
When I try the same thing in French, the Submit and Reset buttons are still labeled in English, and also the word "Required" at the top of the form.
Specifically, I am using the forms like this:
The module is assigned to "All pages," has a template position I made up (newsmformfr), and is assigned to the French language (already working the the site content).
I have an article in a category (not directly off a menu item), with the language assigned to French, and am using {loadposition newsmformfr} to display the module in the page.
This works just fine for the form in English, but not in French. The questions are in French because I put them in that way, but the built-in form elements (the buttons and the word "Required") stay English. Can you please help?
13 years 3 months ago #129 by Administrator AV
Replied by Administrator AV on topic Aw: Multilanguage not working
Hi David,
thanks for that detailed description!
Although I've not tested that construction (module, loadposition in an article without direkt menu link) I think the translation basically works fine, for the questions are in french.
The button texts are the texts you typed in as "label" of the button field. I think you typed in there Submit and Reset in the french form as well?
The "requiered" text comes from the language file. I only made language files for english and german (which is my native tongue) but not for french.
If you want that text to be translated you have to make a french language file.
Create a folder fr-FR in
yourWebsite/components/com_visforms/language
copy the index.html and the en-GB.com_visforms.ini from
yourWebsite/components/com_visforms/language/en-GB into that folder.
Rename the file to fr-FR.com_visforms.ini and translate the strings into french.
Every translation string has to be included by "".
Please let me know, if that solved the problem.
Kind regards,
13 years 3 months ago #130 by xtime123
Replied by xtime123 on topic Re:Aw: Multilanguage not working
Thank you for the quick and helpful reply!
Adding the fr-FR language file worked perfectly, and yes, I forgot to put the French text in for the buttons - my fault!
Thank you again,
Dave
13 years 3 months ago #131 by Administrator AV
Replied by Administrator AV on topic Aw: Re:Aw: Multilanguage not working
Hi Dave,
you are wellcome. I'm glad I could help.
Kind Regards, Aicha
