Le bouton submit de fonctionne pas
8 years 8 months ago #4514 by jquris
Le bouton submit de fonctionne pas was created by jquris
Bonsoir et je m'excuse de poster le problème en français
Si c'est un problème, je peux le poster en anglais.
Le bouton submit ne fonctionne pas. J'ai bien lu les posts concernant les erreurs de javascript mais je ne trouve pas.
Le lien : ocebon.fr/index.php/home/menu-du-jour
Le bouton : "recevoir menu du jour".
Merci d'avance
Cordialement.
8 years 8 months ago #4518 by Administrator AV
Replied by Administrator AV on topic Le bouton submit de fonctionne pas
there is the following javascirpt error on your website:
SyntaxError: missing ] after element list
This error is caused by the following code:
$(function(){
$(".g-textpromo-typed.typewriter-1").typed({
strings: ,
typeSpeed: 0,
preStringTyped: function() {
$(".g-textpromo-typed").css('visibility', 'visible');
Actually in the source code this code looks a bit different because there seems to be a bad caracater in the text or some such thing, and that is what causes the Javascript error in the first place. This Code does not come from Visforms. But I think it breaks Visforms as well.
Please fix this problem first. If the problem with the Visforms buttons are not solved afterwards, please let me know.
