custom layout don't work
8 years 7 months ago #4595 by ciccioroky
custom layout don't work was created by ciccioroky
hi,
i want use visform module with my custom layout selected in te tab "advanced".
my layout don't work.
i have insert only an image with html code but the module don't work .
why?
thanks
8 years 7 months ago #4596 by Administrator AV
Replied by Administrator AV on topic custom layout don't work
I can create a custom layout for the Visforms Module, selected it in the tab advanced in the module configuration and everything works properly. So out of the box this feature is working very well.
So this seems to be a problem of the individual configuration on your website.
Maybe you have not set up the custom layout properly or the problem does not come from the custom module layout in the first place. Does the module work, if you do not use your custom layout? The default layout consists of 4 files. Have you copied and renamed them all properly? What exactly do you mean if you write "don't work"?
8 years 7 months ago - 8 years 7 months ago #4616 by ciccioroky
Replied by ciccioroky on topic custom layout don't work
I, maybe i don't copy and renamed the 4s file properly.
can you explain me where i found this 4 files?
i've copy and renamed only the file default.php in the mod_visform folder.
i've downloaded default.php and insert it in html/mod_visform in my template folder.
Last edit: 8 years 7 months ago by ciccioroky.
8 years 7 months ago - 8 years 7 months ago #4617 by Administrator AV
what you have done, is creating an override not a custom layout.
If you want to create a custom layout, you have to rename the files.
So you copy the 4 .php files which you find in the modules/mod_visforms/tmpl folder to the html/mod_visforms folder in your template.
Then you rename the
default.php -> custom.php
default_btdefault.php -> custom_btdefault.php
default_mcindividual.php -> custom_mcindividual.php
default_visforms.php -> custom_visforms.php
After that, you should be able to select your custom layout in the administration in the module configuration tab "advanced" as "custom".
After that, you can modifiy your custom layout files (add the image..)
Last edit: 8 years 7 months ago by Administrator AV.
