Enable easier ways to order fields on long forms
  • michaelh@notabandoned.org
  • Topic Author
  • Offline
8 years 5 months ago #4796 by michaelh@notabandoned.org
Enable easier ways to order fields on long forms was created by michaelh@notabandoned.org
Hi - another idea for a feature change
changing the order of fields on a form by dragging the field is okay for short forms. However for longer forms this is time consuming. If you could simply add an option to simply number the fields then would be better. Or provide the option to add a new field in a certain location within the ordered list so a new field does not automatically show up at the very bottom.
