How to dispay form fields in two columns
8 years 2 months ago #4905 by parashuram
How to dispay form fields in two columns was created by parashuram
Hello
I would like to display form fields in two columns, is it possible?
How can contribute to you by donating a small amount as I am new to IT Industry. I can contribute 1000 INR as of now.
Thank you
8 years 2 months ago #4906 by Administrator AV
Replied by Administrator AV on topic How to dispay form fields in two columns
please check out this documentation article:
www.vi-solutions.de/en/documentations/vi...0-multi-column-forms
This is how you can display two fields in a column with Visforms.
Have you tried to use the donate button on the right side? You could donate 10 euros. As far as I can see that would be within your reach of 1000 INR.
8 years 2 months ago #4952 by parashuram
Replied by parashuram on topic How to dispay form fields in two columns
Hello Aicha
Thank you for your quick support, as I checked the template which is using is based on Bootstrap 3
Please visit saj.powerphrase.us/index.php/warranty/warranty-registration
If I can achieve this or if you assure me I will go with 1-year subscription
Thank you
Parashuram Singade
8 years 2 months ago #4953 by Administrator AV
Hallo Parashuram Singade,
I have looked at some of the pages of your website.
As far as I can see they are all build with the page builder extension.
I'm not very familiar with this extension and so I cannot say, if the bootstrap 3 grid classes and css, which I can see on your website come from your template itself or from the page builder extension.
Before you buy anything, can you please create a menu item on your website, that displays a Visforms form (a small one with one or two fields is enough). So that I can check on the HTML and CSS available.
8 years 2 months ago #4954 by parashuram
Hello Aicha
I thank you for your support, as you said please find below link
sandbox.winlinesolutions.com/index.php/find-a-dealer
Please let me know if you need admin login - no worries for me in sharing the login credentials - because I believe everyone.
I don't have login details as of now, I am able to retrieve the same if required.
In the above-said link, text area field looks bigger, please have a look at this if possible, because, my client raise a query on this
Thank you
Parashuram Singade
8 years 2 months ago #4955 by Administrator AV
well this looks like a template that implements the complete bootstrap 3 css. So I think the bootstrap 3 layouts from the Visforms Subscription should work but I it is possible that you have to make some minor adjustments to the css (add some custom css).
I think you should try the subscription. If it does not work out, please let me know soon.
