Problem with Export Data on Visforms - Version 3.10.4
7 years 10 months ago #5454 by mali.miloica
Please help,
When I want to do the Export data, I get a mistake:
Fatal error: Call to undefined function iconv() in /home/kpa/public_html/cms/administrator/components/com_visforms/models/visdatas.php on line 310
Line of code: $unicode_str_for_Excel = iconv("UTF-8", "windows-1250//TRANSLIT", $row->$prop);
Can you tell me what I should do?
Visforms Version 3.10.4
Joomla 3.8.7
PHP Version 5.6.35
MySQL Version 5.6.39
7 years 10 months ago #5455 by Administrator AV
Replied by Administrator AV on topic Problem with Export Data on Visforms - Version 3.10.4
This is very strange, because this error has never been reported in the past and now two times in the last few weeks.
The error is due to a missing PHP module on your server.
I have fixed it with Visforms 3.11.2 release candidate which you can get from the download menu on our website.
Alternatively you can set the export option Use Windows-1250 character set to no. This should fix the problem too.
7 years 10 months ago - 7 years 10 months ago #5456 by mali.miloica
Thanks for your reply.
I tried the option Windows-1250 character set to no... earlier
however, still the same problem. :-/
I also checked php extensions and iconv is installed.
P.s Visforms 3.11.2 release candidate fix this problem. :-)
Best regards,
Milan
Last edit: 7 years 10 months ago by mali.miloica.
7 years 10 months ago #5457 by Administrator AV
Hi Milan,
thanks a lot for your reply!
Although I do not understand, why setting the option to "no" does not fix the problem and how it is possible that you run into the problem in the first place, if the php extions in available (I will take a look into this), it is good to know, that the bugfix, which I added in Visforms 3.11.2 does work.
Kind Regards,
