[SOLVED] geocode was not successful for the following reason request_denied
7 years 9 months ago - 7 years 9 months ago #5573 by NurArt
Good morning,
I have a little problem with the google map location field.. I get the error "geocode was not successful for the following reason request_denied". I inserted the API key but it doesn't work.
Please can you help?
This is my test link:
www.galstaffmultiresine.it/index.php?opt...ticle&id=140&lang=en
Thank you very much
best regards
Last edit: 7 years 9 months ago by NurArt.
7 years 9 months ago #5574 by NurArt
I solved the problem.
The ussue was given by the new system of google maps.
The API key must be created under the "PLACES" category on google consolle.
7 years 9 months ago #5575 by Administrator AV
thanks for reporting the problem and sharing the solution!
I'm sorry, I was out of office today. Therefore I just noticed your post now, after you had already solved the problem yourself.
The following user(s) said Thank You: NurArt
