Need to edit the frontend display
7 years 9 months ago #5576 by Tiko
Need to edit the frontend display was created by Tiko
Hi guys,
We are using you component Visforms on our travel agency website and we are very happy with it (works like a charm)
Now, we would like to edit the frontend display to reduce the height of the page (reduce the scrolldown).
For example, how can we display the multicheckboxes and the radio buttons horizontaly, please?
We also would like to display the dates choices on the same line (departure - return).
Thanks again for your component and for your next message.
7 years 9 months ago #5577 by Administrator AV
Replied by Administrator AV on topic Need to edit the frontend display
there is an option in the field configuration of fields of type radio and checkbox group, where you can select, whether the options should be displayed "in line" or "as list" (Tab "Basic Options" on the right side, "Display"). If you have already set this option to "in line" and the options are still not displayed in line in the frontend, then the reason for this could be, that the form layout, which you have selected in the form configuration on the tab "advanced" does not fit with your template. See: www.vi-solutions.de/en/documentations/vi...layout-configuration
The other feature, which you want to use in order to put more than one form field into a row, is the multi column layout: www.vi-solutions.de/en/documentations/vi...0-multi-column-forms
(respectively www.vi-solutions.de/en/documentations/bo...h-bootstrap-3-layout if you finally end up with the bootstrap 3 layout)
7 years 9 months ago #5578 by Tiko
Replied by Tiko on topic Need to edit the frontend display
Vilen Dank, it's perfect :)
7 years 9 months ago #5579 by Administrator AV
Thanks, you're welcome!
