404 Not Found - send messge
7 years 8 months ago #5680 by tomasz
404 Not Found - send messge was created by tomasz
On the page → polish-export[at]eu/kontakt.html I have a form. When I click "Wyślij" I have an error:
404 Not Found The request /index.php?option=com_visforms&task=visforms.send&id=1 was not found on this server.
What additional work should I do?
7 years 8 months ago #5684 by Administrator AV
Replied by Administrator AV on topic 404 Not Found - send messge
it looks as if the base url is missing in this link but I have no idea where this might come form. Usually the Joomla! Router should ad the base url by automatic action. I have not heard of this problem before, so I think it is a configuraiton problem specific to your website.
You publish the form with a module, maybe if you would create a menu item of type Visforms for this form (in a hidden menu) and then set the module option "corresponding menu item" to this menu item. But I'm not sure if that will help.
