No advanced options in field
6 years 9 months ago #6246 by badback1987
No advanced options in field was created by badback1987
Im trying to setup a formto display in front end, and so far all it displays is the form name without any fields.
Ive followed the instructions but I cant find where the advanced tab is in the field section to set that field to display in the front end. The only option there is basic options.
Any idea what im missing?
Thanks
6 years 9 months ago #6247 by Administrator AV
Replied by Administrator AV on topic No advanced options in field
that sounds very strange.
Usually, if you want to add a field to the form, you only have to create and save the field and without any further action, it will be displayed in the form.
The options on the "Advanced" field configuration tab are only to set up for example whether the submitted form data are displayed in the frontend DATA views or whether they can be exported to a csv file etc.
Would it be possible to give me admin access so that I could take a look at the visforms administration on your website? (Please send login to contact@vi-solutions.de then).
