Front view on Multiple Layout
6 years 8 months ago #6270 by akshehu
Front view on Multiple Layout was created by akshehu
Hello..
Please when i set my form as multiple layout or bootstrap 3 multiple layout.
How can i get the front view to be exactly the way the multiple layout of the form is? So the submitted data in the front view will not just be a vertical data table but to follow how the form was layout before submission.
How can i achieve this.
Thank you
6 years 8 months ago #6272 by Administrator AV
Replied by Administrator AV on topic Front view on Multiple Layout
the frontend data view has nothing to to with the form and it's layout.
It is a way to publish selected data in the frontend. Therefore it has the list layout.
6 years 8 months ago #6273 by akshehu
Replied by akshehu on topic Front view on Multiple Layout
Alright.
Thank you..
But then if the form has nothing do with front display.
Is it possible to structure the front display in like multiple layout ? or its just list ONLY
6 years 8 months ago #6274 by Administrator AV
In the first place it is list ONLY. You can enable a detail view, too (form configuration, tab "Data view in frontend", which can be accessed from the list view and you can try to add custom css in order to give another layout to that detail view.
I actually do not now exactly what you mean with multiple layout? (Multi column layout or multi page layout?) But neither of this is available out of the box in the data views.
