SQL
6 years 1 month ago #6526 by av_74
SQL was created by av_74
Hello
I would like to fill in a Select field using an SQL query: SELECT * FROM `aspt_visforms_1`
But I can't find where to put this request
Thank you for your help
Visforms Subscription Visform 3.12.10
6 years 1 month ago #6528 by Administrator AV
Replied by Administrator AV on topic SQL
the fields that can create options form sql-Statements (listboxsql, radiosql and multicheckboxsql) where added to visForms 3.13.x/subscription 3.4.x, which are currently available as beta versions.
You have to update to visForms 3.13.9 and Subscription 3.4.7, if you want to use this feature.
As we do not distribute beta versions via Joomla! update manager, you have to download the installation packages from the downloads menu manually.
6 years 1 month ago #6530 by av_74
Replied by av_74 on topic SQL
Thank you the SQL fields appear now
When I test the request I have: success: found 10 entries
but they do not appear in the Select field of the form
6 years 1 month ago - 6 years 1 month ago #6531 by Administrator AV
if you use the sql statement
this can obviously not work.
Which information from this * should be use in the option list?
As stated in the documentation ( www.vi-solutions.de/en/documentations/do...m-database-using-sql ), which I would like you study carefully, "The SQL statement must return a value and a label"!
Last edit: 6 years 1 month ago by Administrator AV.
6 years 1 month ago #6532 by av_74
sorry I forgot to specify the field
SELECT `F1` FROM `aspt_visforms_1` WHERE 1
but it doesn't work :(
6 years 1 month ago #6533 by Administrator AV
please check out the documentation. "The SQL statement must return a value and a label"!
Your sql-Statement is still not correct. It cannot work with regards to creating listbox options.
