Form not selectable for Front-End Editing Menu Link?
5 years 9 months ago #6888 by NativeRadio
I've created a form, changed permissions to a specific group (Facilities) and when I try to create a menu link to Front-end Editing, the form is not available (shown) for selection, in anything other than a link to the form itself?
Please tell me how to enable Front-end editing for our form.
howardm1.sg-host.com/homepage/facilities/work-order-request
The form is under Home >> Facilities >> Work Order Request
Thank you for your help!!
5 years 9 months ago #6889 by Administrator AV
Replied by Administrator AV on topic Form not selectable for Front-End Editing Menu Link?
I'm not totally sure, whether I understand correctly, what you are asking for.
visForms allows you to edit submited form data.
First you have to enable the form option "Save Results". You find this option in the form configuration on the "Result"-Tab.
After the you can create a menu item of type "visForms data view with edit link".
In the form selection of this menu item you should be able to select the form.
Maybe this documentation is of help: www.vi-solutions.de/en/documentations/vf...ension-documentation
Regards Aicha
