Problem with Submitting new Instances of form and saving Edits
  • nick.birch@exigia.com
  • Topic Author
  • Offline
4 years 10 months ago #7396 by nick.birch@exigia.com
Replied by nick.birch@exigia.com on topic Problem with Submitting new Instances of form and saving Edits
OK and thanks.
I will have to methodically work through other extensions and configuration first and let you know if I need more assistance.
While I am on this subject of front end display, have I missed an option to display the Edit button when displaying records in a front end article as well as in a menu option? If I had that (and can get editing working), my application would be exactly what I am aiming for. It's 90% there now and a great improvement on previous versionsI have set up with other products.
Thanks
Nick
4 years 10 months ago #7399 by Administrator AV
Hi Nick,
the frontend edit views (edit button) are only accessable through menu items of type visforms >> formdata with edit view and visforms >> my submissions.
Frontend edit views (edit button) are not accessable when you use the content plugin visforms data view (when you are inside an article).
Whether or not the edit button is displayed with the visforms menu items, depends on the permissions settings and the menu settings.
  • Topic Author
  • Offline
4 years 10 months ago #7402 by nick.birch@exigia.com
I thought you might like to know that I have found what seems to have been the issue.
Edit worked when I disabled the Front End cleaning option of the Regular Labs Cache Cleaner plugin.
4 years 10 months ago #7405 by Administrator AV
thanks a lot, for sharing this information.
