Problem with viewing form results frontend
4 years 8 months ago #7602 by Daviciacus
Problem with viewing form results frontend was created by Daviciacus
Hello,
I am trying to set up a menu item to display the results of a particular form frontend on the site for a certain user group. I have enabled this in the general options of the extension, and also in the settings of one form (the one I am testing with a menu item so far).
However, the result is that not much is displayed. For every result of that form, I only see three things: ID, IP address and date (which I have all enabled indeed). But none of the other fields are listed, nor what was submitted in them.
Can you please let me know what I did wrong and how I can fix this?
Thank you.
4 years 8 months ago #7603 by Administrator AV
Replied by Administrator AV on topic Problem with viewing form results frontend
Visforms is very restrictive in order to prevent submitted data from accidentally being displayed in the frontend.
Therefore you you want the submitted data to be visible for a specific field, you have to actively allow this in the field configuration.
You find this option "Frontend Display" in the FIELD-konfiguration on the tab "Advanced".
4 years 8 months ago #7604 by Daviciacus
Replied by Daviciacus on topic Problem with viewing form results frontend
Thanks for your reply, I found it now.
It looks like I have to do this for every field in every form I have created. Does this mean that I have to do this manually on all fields? Or is there an easier way to do this simultaneously for multiple fields?
Thanks.
4 years 8 months ago #7605 by Administrator AV
glad you found it.
I'm sorry but you have to do it manually on each field.
4 years 8 months ago #7608 by Daviciacus
Thanks,
It would have been handy to do this as batch action, but manually works too - fortunately it's only a one time thing to do. As long as it works, that's most important!
Thanks!
