textarea does not display data in form with edit
4 years 5 months ago #7680 by janbulens
If i open a form with the menu:  form with edit, then the textarea does not display data. But when set in the basic field options HTML edit to off, then the data is displayed? Is this a bug?
I am using joomla 4
4 years 5 months ago #7681 by Administrator AV
Replied by Administrator AV on topic textarea does not display data in form with edit
Hi, with regards to the fact, that you are on Joomla 4, this could be a bug. I have to take a look at this as soon as possible.
Regards, Aicha
4 years 5 months ago #7689 by Administrator AV
I took a look into this.
Yes, you found a bug in Visforms for Joomla! 4
I will fix this as soon as possible, but it may take a view days.
I'm sorry for your trouble!
4 years 2 months ago - 4 years 2 months ago #7857 by Administrator AV
Addendum:
The error regarding the 'HTML Editor' setting for the textarea was a bug in Visforms and was finally fixed on 03.11.2021 with Visforms 4.1.3.
Last edit: 4 years 2 months ago by Administrator AV.
