Problems installing on Joomla 4
3 years 6 months ago #8424 by cjsmiff
Problems installing on Joomla 4 was created by cjsmiff
Installation says successful but when going to the component (Dashboard, Forms and Form Factory) I am getting the following error:
0 Class 'Visolutions\Component\Visforms\Administrator\Extension\VisformsComponent' not found
I am using Joomla 4.2.3 (have tried with 4.1.5 too), PHP 8.1 (have tried with 8.0 & 7.4 too).
I have checked Joomla - Maintenance - Database and everything says it is up to date.
Any idea how I can fix this please?
Kind regards
Claire :-)
3 years 6 months ago #8432 by Administrator IV
Replied by Administrator IV on topic Problems installing on Joomla 4
Hello Claire,
the installation either runs completely or not at all and suppresses any error messages.
Please also see here:
docs.joomla-4.visforms.vi-solutions.de/e...as-really-successful
And the installation verification here:
docs.joomla-4.visforms.vi-solutions.de/e...tion-fully-installed
Your description matches an incomplete installation.
Our experience is that Joomla 4 has incomplete installations much more often than Joomla 3.
In our experience, after a new installation, it usually worked.
I therefore recommend that you simply carry out the installation at least one more time.
If this should also not lead to success, a detailed error report would be very helpful for us.
To get an accurate error report, enable maximum debugging in the Joomla administration before reproducing the error:
Kind regards, Ingmar
3 years 6 months ago - 3 years 6 months ago #8433 by Administrator IV
Hello Claire,
Sufficient write permissions for the file system within the Joomla instance are also important.
Please check whether this is actually the case.
If repeating the installation and the debugging information doesn't help, the question is whether you can provide us with an Akeeba backup of the site.
We use the following platform for this purpose:
wetransfer.com/
Last edit: 3 years 6 months ago by Administrator IV.
3 years 6 months ago #8441 by cjsmiff
Replied by cjsmiff on topic Problems installing on Joomla 4
Hi Ingmar,
Thank you for your reply. I have tried installing it again, several times. The debug doesn't mean much to me but says:
# Function Location
1 () JROOT/administrator/components/com_visforms/services/provider.php:45
2 Joomla\DI\ServiceProviderInterface@anonymous/home/jhireco/public_html/administrator/components/com_visforms/services/provider.php:25$0->{closure}() JROOT/libraries/vendor/joomla/di/src/ContainerResource.php:182
3 Joomla\DI\ContainerResource->getInstance() JROOT/libraries/vendor/joomla/di/src/Container.php:96
4 Joomla\DI\Container->get() JROOT/libraries/src/Extension/ExtensionManagerTrait.php:174
5 Joomla\CMS\Application\CMSApplication->loadExtension() JROOT/libraries/src/Extension/ExtensionManagerTrait.php:50
6 Joomla\CMS\Application\CMSApplication->bootComponent() JROOT/libraries/src/Component/ComponentHelper.php:355
7 Joomla\CMS\Component\ComponentHelper::renderComponent() JROOT/libraries/src/Application/AdministratorApplication.php:143
8 Joomla\CMS\Application\AdministratorApplication->dispatch() JROOT/libraries/src/Application/AdministratorApplication.php:186
9 Joomla\CMS\Application\AdministratorApplication->doExecute() JROOT/libraries/src/Application/CMSApplication.php:294
10 Joomla\CMS\Application\CMSApplication->execute() JROOT/administrator/includes/app.php:61
11 require_once() JROOT/administrator/index.php:32
How do I send you the admin log in via wetransfer please?
Kind regards
Claire :-)
3 years 6 months ago #8444 by Administrator IV
Hello Claire,
please excuse the late reply!
I had a few days off.
Sending files with WeTransfer is really very easy.
On the WeTransfer website:
- Create an account and be logged in.
- Fill out the small transfer dialog:
vi-solutions.de/forum-uploads/wetransfer-upload-files_empty.png
- Click on the blue plus button and add the desired file.
- Enter our email address (contact@vi-solutiuons.de) as 'Email to'.
- Your sender email address is already entered.
- Click on the blue button 'Transfer'.
vi-solutions.de/forum-uploads/wetransfer...oad-files_filled.png
- You will get a small transfer summary.
vi-solutions.de/forum-uploads/wetransfer...oad-files_result.png
- The sender receives an email notifying about the transfer with the download link.
- The recipient receives an email notifying them of the transfer with their personal download link.
vi-solutions.de/forum-uploads/wetransfer...d-files_download.png
Please send us the log file and an Akeeba backup of the affected website.
I would be best served with the Akeeba backup of the affected website.
