Submit button not visible
3 years 2 months ago - 3 years 2 months ago #8869 by markus99
Submit button not visible was created by markus99
I don't see image button and I've an error about size of files (the file is too large. Max size is 0 kb).
Here it is the image of the error:
ibb.co/VtLq5wP
Thanks.
Last edit: 3 years 2 months ago by markus99.
3 years 2 months ago - 3 years 2 months ago #8871 by Administrator AV
Replied by Administrator AV on topic Submit button not visible
Hi Marcus99,
the image, used as button, is simply missing on the new website.
If you use external resources in your forms, you have to make sure, that after moving forms with export/import from one website to another, these resources are available on the new website, too.
Just upload the image or go to the field configuration and select an exising image.
Last edit: 3 years 2 months ago by Administrator AV.
3 years 2 months ago #8873 by markus99
Replied by markus99 on topic Submit button not visible
That's good! thanks!
