Initial value for hidden field
12 years 7 months ago #259 by lidija
Initial value for hidden field was created by lidija
Hello.
I've added the same form in different articles. Now I would like to add a hidden field to this form. The initial value of the hidden field should be the article's title/id/url, so that I can know from which article the form was submitted.
Is there a way to do this?
Kind regards,
Lidija
12 years 7 months ago #260 by Administrator AV
Replied by Administrator AV on topic Re:Initial value for hidden field
HyLidija,
thats not possible for the moment. You can't use a variable or parameter as default value.
Nevertheless it is very easy to duplicate a form with all it's settings and fields (using the
"Dublicate" Button). Maybe that's a workaround?
Kind regards,
12 years 7 months ago #265 by lidija
Replied by lidija on topic Re:Initial value for hidden field
thank you for your answer. This should do for now.
Kind regards,
Lidija
