Location field
  • geert@huizechaos.be
  • Topic Author
  • Offline
2 years 5 months ago #10065 by geert@huizechaos.be
Location field was created by geert@huizechaos.be
Hi, I'm using Visforms subscription and I would like to add a location field. The user would have to click on the map and the coordinates should go to the database. Is this possible? I can't get it to work...
Geert
2 years 5 months ago #10066 by Administrator IV
Replied by Administrator IV on topic Location field
Hello Geert,
Answer to 'Is this possible? ':
Yes, that is of course possible.
Answer to 'I can't get it to work...':
Usage is described in the documentation.
Field Type Location/Map:
docs.joomla-4.visforms.vi-solutions.de/e...d-types/geolocation/
In principle, the points in this section are particularly important.
Getting Started:
docs.joomla-4.visforms.vi-solutions.de/e...ocation/first-steps/
Quote:
Note: You need a Google Maps API Key.
If you want to use the map function of the location field, you need a Google Maps API key. You can get this key from Google.
Everything you need to know to use the Location/Map field type is described in the documentation.
Kind regards, Ingmar
  • Topic Author
  • Offline
2 years 5 months ago #10068 by geert@huizechaos.be
Replied by geert@huizechaos.be on topic Location field
Indeed i forgot the Google Maps Key...
Now the form 'tries' to display the map but an error message is shown telling me to check the Javascript console.
I enabled debugging in the system and now the error does not appear but no map either.
Thanks for your precious help,
Geert
  • Topic Author
  • Offline
2 years 5 months ago #10069 by geert@huizechaos.be
It started working after some time, maybe there's a delay in the validation of the google maps key?
Thanks again,
Geert
2 years 5 months ago #10070 by Administrator IV
Hello Geert,
I expect that the 'Location/Map' type field will also work without errors for you.
There are no known similar issues.
Activating PHP debugging in Joomla doesn't really help you with JavaScript problems.
First of all, this is about possible JavaScript errors.
You have to pursue these first.
Maybe you have a JavaScript error on the page.
You can find out by opening the console in the web browser's developer tools.
All errors and warnings since the page was loaded are listed there.
In the web browser of your choice, go to the website you want to examine and open the developer tools:
- In Firefox in the menu under: Extras -> Web Developer -> Show/Hide Tool.
- In Google Chrome in the menu under: more tools -> developer tools.
- In Internet Explorer in the menu under: Developer tools (F12 key).
2 years 5 months ago #10071 by Administrator IV
Hello Geert,
re: 'maybe there's a delay in the validation of the google maps key':
This may well be possible or something similar or just a few times at the beginning.
Watch it for a while...
Greetings, Ingmar
