Location field
  • geert@huizechaos.be
  • Topic Author
  • Offline
2 years 7 months ago #10073 by geert@huizechaos.be
Replied by geert@huizechaos.be on topic Location field
I have my map up and running, on my desktop I do a right-clich and choose to set a marker. On my Android phone, everyone says I must long-click to set a marker but that does'nt work. In the maps app it works this way but not on my form.
2 years 7 months ago #10074 by Administrator IV
Replied by Administrator IV on topic Location field
Hello Geert,
We released the 'Context Menu' feature for Visforms 4.2.1 on November 28, 2023.
[VF-647] Forum: Google Maps API: Add context menu to map
The feature was requested by Josef.
vi-solutions.de/de/forum/17-joomla-templ...241-google-maps#8523
Josef tested it and reported the same error as you: Android 13 with Firefox, Samsung Internet and Via browser no response.
vi-solutions.de/de/forum/17-joomla-templ...le-maps?start=6#8672
I then created a second issue:
Issue [VF-679] Forum: Google Maps API: Context menu: Works on Firefox only
I'll take a look at this soon and fix the error.
Thank you again for your patience!
Kind regards, Ingmar
  • Topic Author
  • Offline
2 years 7 months ago #10075 by geert@huizechaos.be
Wow, I am amazed with your quick and to the point support!!!
Thanks very much, the form is to be used to track beekeepers of our region in a scientific study.
2 years 7 months ago #10093 by Administrator IV
Hello Geert,
Thank you very much for your motivating feedback!
Kind Regards, Ingmar
  • Topic Author
  • Offline
2 years 6 months ago #10104 by geert@huizechaos.be
Hello,
Would it be possible to give me an idea when the bug fix would be available?
Our beekeeper-tracking form should go live in two weeks. I could always replace the location field with an 'address' field but that's not practical for processing the data.
Kind regards,
Geert
2 years 6 months ago #10107 by Administrator IV
Hello Geert,
I'm afraid it doesn't come down to simply finding an error and fixing it straight away.
Most likely, the way it is implemented will have to be completely changed to make it work on the mobile platform.
So I can neither estimate nor promise that it will be resolved within 2 weeks.
I'm sorry I can't give you another answer.
I'll definitely take a look at it during this time.
With luck, it might not be a big deal after all.
