field separator
12 years 6 months ago #279 by donleo78
field separator was created by donleo78
Hi! I find this extension awesome! i can create a great form in minutes.
I find only some minor problems:
the label of the fields are too small, but i solved it via css (width:100%, same with input field), but maybe that interferes with the separator field (i wanted to put Name and Surname in separate fields, but in same line).
It works fine with buttons anyway.
Anyway, great extension! Thanks a lot!
12 years 6 months ago #280 by Administrator AV
Replied by Administrator AV on topic Re:field separator
Hi donleo78,
it's very encouraging to get such a response. Thank you very much!
At the moment the structure is that the label is displayed as a block element that is floated to the left. The input just follows the label. Each label/input pair is wrapped in a div. After the div there is a p element with clear both which causes the next label to be displayed in a new "line".
At first thought I can't see an easy way to display two label/input pair in one line. Sorry.
Kind Regards,
12 years 6 months ago #283 by donleo78
Replied by donleo78 on topic Re:field separator
Thanks for the answer! :cheer:
mmm, I undesrtand now... maybe with some specific css class and position or floating...
i will try and see what happens... and of course I will share the answer if i find it.
See ya!
