Syntax does not work
1 year 4 months ago - 1 year 4 months ago #11494 by umif
Syntax does not work was created by umif
Dear Support Team,
We have created two visforms which we called A and B.
When I input some new contents in form A, the newly input contents could be found on the server,
But in form B, the newly input contents could not be recorgnized by "Select SQL".
The SQL-Select-Statement was used so far is as following:
SELECT DISTINCT `F85` as value,`F85` as label FROM `jos4_visforms_10` WHERE `F81` in OR `F82` in ORDER BY `F81`ASC, `F82`ASC
When I click "Test", there is an error message shows as following:
You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'OR `F82` in ORDER BY `F81`ASC, `F82`ASC' at line 1
What we did is to update the Joomla to a MariaDB10.4 server.
Therefore could you please help us solve this problem at your earliest convenience as we need to provide these two visforms on a daily basis to our users.
Thank you so much and we are looking forward to your professional suggestions.
Last edit: 1 year 4 months ago by Administrator IV.
1 year 4 months ago - 1 year 4 months ago #11500 by Administrator IV
Replied by Administrator IV on topic Syntax does not work
Hello umif,
quote from above: Important information for almost every question:
The SQL statement mentioned is incorrect and contains two errors.
To quickly obtain more detailed information about possible errors, you can execute the SQL statement in a dedicated SQL editor.
Such as phpMyAdmin or another SQL development environment.
Visforms, of course, cannot perform this precise analysis.
SQL statement:
Error 1:
The list of values ​​is missing after the keyword 'in'.
WHERE `F81` in OR
Error 2:
`F82` in ORDER BY
The SQL IN Operator:
www.w3schools.com/sql/sql_in.asp
SELECT * FROM Customers WHERE Country IN ('Germany', 'France', 'UK');
Question:
It's possible that you're using a Visforms parameter in the SQL statement and something's wrong.
Does the SQL statement exactly match the SQL statement from the field configuration?
Best regards, Ingmar
1 year 4 months ago #11503 by umif
Replied by umif on topic Syntax does not work
Hi Ingmar, wrote:
1 year 4 months ago - 1 year 4 months ago #11504 by umif
Hi Ingmar,
Thank you so much for your prompt feedback. Yesterday when I copied the  Syntax there was an issue, the complete SQL-Select-Statement is as followings:
SELECT DISTINCT `F85` as value,`F85` as label FROM `jos4_visforms_10` WHERE `F81` in ${input:project-leader-list} OR `F82` in ${input:project-leader-list} ORDER BY `F81`ASC, `F82`ASC
When I clicked "Test", the error shows as below:
The Version of Visform we use is: 4.4.3,
the Version of Joomla is: 5.1.4,
the PhpMyAdmin is: MariaDB-10.4
Looking forward to hearing from you for further support and help. Many thanks in advance.
Best,
Shuting
1 year 4 months ago #11505 by Administrator IV
Hello Shuting,
Thanks for the version information and the original SQL statement, which, as expected, contains two Visforms placeholders.
Re: Error after pressing the test button.
The error after pressing the test button occurs because the SQL statement contains Visforms placeholders.
For simple testing with the test button directly in the form configuration, no Visforms placeholders for form fields must be included.
Everything else is described in the documentation.
The test button:
docs.joomla-5.visforms.vi-solutions.de/e...ist/#the-test-button
I can't say at this point whether your SQL statement works in the running form or not.
This is solely about the error when using the test button.
Kind regards, Ingmar
